跳转到主内容
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
你所需要的
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: 步骤 1 中的图像 1,2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: 步骤 1 中的图像 2,2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 2 中的图像 1,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 2 中的图像 2,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 2 中的图像 3,3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 3 中的图像 1,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 3 中的图像 2,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 3 中的图像 3,3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 4 中的图像 1,2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 4 中的图像 2,2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 5 中的图像 1,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 5 中的图像 2,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 5 中的图像 3,3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 6 中的图像 1,2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 6 中的图像 2,2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 7 中的图像 1,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 7 中的图像 2,3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: 步骤 7 中的图像 3,3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
结论
2等其他人完成本指南。
August Post
于11/07/17注册
415 声望
创作了3篇指南
团队
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S2G4
3 名成员
创作了4篇指南
一条评论
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 523
