跳转到主内容
Philips Norelco 5801XL Front and Back Housing Replacement
你所需要的
  1. Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: 步骤 1 中的图像 1,2 Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: 步骤 1 中的图像 2,2
    • Remove the two T8 2 mm Phillips screws on the back housing.
  2. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 2 中的图像 1,2 Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 2 中的图像 2,2
    • Separate the back housing and the front housing using the plastic opening tool.
  3. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 3 中的图像 1,3 Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 3 中的图像 2,3 Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool, carefully pry the inside of the middle bracket towards the outside of the housing in order to remove it.
  4. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 4 中的图像 1,1
    • Remove the two T8 2 mm screws near the bottom of the device.
    • Remove the bracket the screws were holding in place.
  5. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 5 中的图像 1,1
    • Insert the plastic opening tool into the charging port and push inwards.
  6. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 6 中的图像 1,1
    • Remove the two T8 2 mm screws near the top of the device shown here.
  7. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 7 中的图像 1,3 Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 7 中的图像 2,3 Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 7 中的图像 3,3
    • Cautiously lift and twist the circuit board, then begin sliding the inside assembly forward.
    • After sliding it forward, the whole assembly will separate from the rear housing.
  8. Philips Norelco 5801XL Front and Back Housing Replacement: 步骤 8 中的图像 1,1
    • The housing and the inside assembly should be completely separated.
结论
Now, you can put the new housing on. To reassemble your device, follow these instructions in reverse order.
Ben Gibbs
于02/16/16注册
361 声望
创作了3篇指南
团队
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 600
