跳转到主内容
Philips Emerson CoughAssist CA Series Disassembly
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Philips Emerson CoughAssist CA Series Disassembly, Philips Emerson CoughAssist CA Series Disassembly: 步骤 1 中的图像 1,1
    • First, remove the two 16mm pan head screws (1) directly under the front panel of the ventilator. (Page 3).
    • Next, remove the two 16mm flat head screws (3) from the back panel of the ventilator. (Page 3).
    • Lift off the top cover (2) of the device. (Page 3).
  2. Philips Emerson CoughAssist CA Series Disassembly: 步骤 4 中的图像 1,2 Philips Emerson CoughAssist CA Series Disassembly: 步骤 4 中的图像 2,2
    • Now remove the "Inhale flow" control knob (4) and "Inhale pressure" knob (4), by loosening the setscrew on each before pulling off. If you have a CM model, carefully remove the Manual Control Lever (3) by prying it off with the screwdriver. (Page 3).
  3. Philips Emerson CoughAssist CA Series Disassembly: 步骤 5 中的图像 1,1
    • Unscrew the three 12.7mm plastite screws ( 2) holding the panel assembly to the lower housing. A long Phillips screwdriver is very helpful for access to the three screws. (Page 3)
    • The front control panel (5) should now be loose. Carefully slide it forwards to remove. (Page 4).
结论
Zachary Stednitz
于04/07/20注册
292 声望
创作了2篇指南
团队
Cal Poly, Team S11-G18, Paton Spring 2020 Cal Poly, Team S11-G18, Paton Spring 2020 的会员
CPSU-PATON-S20S11G18
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 238
