跳转到主内容
Philips DVP642 Power Supply Replacement
你所需要的
  1. Philips DVP642 Power Supply Replacement, Top Panel: 步骤 1 中的图像 1,2 Philips DVP642 Power Supply Replacement, Top Panel: 步骤 1 中的图像 2,2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: 步骤 2 中的图像 1,2 Philips DVP642 Power Supply Replacement: 步骤 2 中的图像 2,2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: 步骤 3 中的图像 1,2 Philips DVP642 Power Supply Replacement, Power Supply: 步骤 3 中的图像 2,2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: 步骤 5 中的图像 1,2 Philips DVP642 Power Supply Replacement: 步骤 5 中的图像 2,2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: 步骤 6 中的图像 1,2 Philips DVP642 Power Supply Replacement: 步骤 6 中的图像 2,2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: 步骤 7 中的图像 1,3 Philips DVP642 Power Supply Replacement: 步骤 7 中的图像 2,3 Philips DVP642 Power Supply Replacement: 步骤 7 中的图像 3,3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: 步骤 8 中的图像 1,2 Philips DVP642 Power Supply Replacement: 步骤 8 中的图像 2,2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
结论
7等其他人完成本指南。
团队
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G20
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 45
总计 13,016
