跳转到主内容
Philips DVP642 Motherboard Replacement
你所需要的
  1. Philips DVP642 Motherboard Replacement, Top Panel: 步骤 1 中的图像 1,2 Philips DVP642 Motherboard Replacement, Top Panel: 步骤 1 中的图像 2,2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    When i put in a dvd the dvd player want open
    I have to unplug it and plug it back in, so it
    will open. If I don't put a dvd in it opens and'
    closes fine. What's causing this ?
    John Bailey - 回复
  2. Philips DVP642 Motherboard Replacement: 步骤 2 中的图像 1,2 Philips DVP642 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Philips DVP642 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Philips DVP642 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Locate the first three ribbon wires.
    • Remove the ribbon wires by grasping firmly as near to the plastic head as possible and pulling.
    • Be firm, but gentle when pulling to avoid pulling the wires off the head.
  4. Philips DVP642 Motherboard Replacement: 步骤 4 中的图像 1,3 Philips DVP642 Motherboard Replacement: 步骤 4 中的图像 2,3 Philips DVP642 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the fourth ribbon wire as in step 2.
    • Remove the fifth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull black clip up, insert the ribbon wire, and push the black clip back down.
  5. Philips DVP642 Motherboard Replacement: 步骤 5 中的图像 1,2 Philips DVP642 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the following screws:
    • 7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
    • Remove the 7.5 mm Phillips screw on the bottom right that attaches the grounding wire to the disc tray.
    • 7.5 mm Phillips screws (4) on outside of player near input/output plugs.
  6. Philips DVP642 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard by pulling it back and then up gently.
    • The input/output plugs should slide out easily from the holes in the back panel.
结论
6等其他人完成本指南。
Nathan Klammer
于10/06/11注册
461 声望
创作了3篇指南
团队
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G20
4 名成员
创作了7篇指南
一条评论
Dvp3005/Ik mother bord .how much price
Md Younus - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 30
总计 11,669
