跳转到主内容
Philips DVP5992-F7 USB port Replacement
你所需要的
  1. Philips DVP5992-F7 USB port Replacement, USB port: 步骤 1 中的图像 1,3 Philips DVP5992-F7 USB port Replacement, USB port: 步骤 1 中的图像 2,3 Philips DVP5992-F7 USB port Replacement, USB port: 步骤 1 中的图像 3,3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 USB port Replacement: 步骤 2 中的图像 1,2 Philips DVP5992-F7 USB port Replacement: 步骤 2 中的图像 2,2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 USB port Replacement: 步骤 3 中的图像 1,3 Philips DVP5992-F7 USB port Replacement: 步骤 3 中的图像 2,3 Philips DVP5992-F7 USB port Replacement: 步骤 3 中的图像 3,3
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  4. Philips DVP5992-F7 USB port Replacement: 步骤 4 中的图像 1,2 Philips DVP5992-F7 USB port Replacement: 步骤 4 中的图像 2,2
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  5. Philips DVP5992-F7 USB port Replacement: 步骤 5 中的图像 1,2 Philips DVP5992-F7 USB port Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 533
