跳转到主内容
Philips DVP5992-F7 Tray Replacement
你所需要的
  1. Philips DVP5992-F7 Tray Replacement, Tray: 步骤 1 中的图像 1,3 Philips DVP5992-F7 Tray Replacement, Tray: 步骤 1 中的图像 2,3 Philips DVP5992-F7 Tray Replacement, Tray: 步骤 1 中的图像 3,3
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: 步骤 2 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 2 中的图像 2,2
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: 步骤 3 中的图像 1,3 Philips DVP5992-F7 Tray Replacement: 步骤 3 中的图像 2,3 Philips DVP5992-F7 Tray Replacement: 步骤 3 中的图像 3,3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: 步骤 4 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 4 中的图像 2,2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: 步骤 5 中的图像 1,3 Philips DVP5992-F7 Tray Replacement: 步骤 5 中的图像 2,3 Philips DVP5992-F7 Tray Replacement: 步骤 5 中的图像 3,3
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: 步骤 6 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 6 中的图像 2,2
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: 步骤 7 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 7 中的图像 2,2
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: 步骤 8 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 8 中的图像 2,2
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: 步骤 9 中的图像 1,2 Philips DVP5992-F7 Tray Replacement: 步骤 9 中的图像 2,2
    • Lift the tray out of the DVD player from the back.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 492
