跳转到主内容
Philips DVP5992-F7 Screen Replacement
你所需要的
  1. Philips DVP5992-F7 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Philips DVP5992-F7 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Philips DVP5992-F7 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Screen Replacement: 步骤 2 中的图像 1,2 Philips DVP5992-F7 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Screen Replacement: 步骤 3 中的图像 1,3 Philips DVP5992-F7 Screen Replacement: 步骤 3 中的图像 2,3 Philips DVP5992-F7 Screen Replacement: 步骤 3 中的图像 3,3
    • Unplug the bundled cable connector that attaches the screen to the motherboard.
    • Remove the 3.175 mm Phillips #1 screw that connects the screen's ground wire to the shell of the DVD player.
    • Remove the three 6.35 mm Phillips #1 screws that attach the screen to the front cover of the DVD player.
  4. Philips DVP5992-F7 Screen Replacement: 步骤 4 中的图像 1,2 Philips DVP5992-F7 Screen Replacement: 步骤 4 中的图像 2,2
    • Slowly pull the screen backwards starting with the side farthest from the disc tray.
    • Unplug the bundled cable connector that is located close to the disc tray as you pull the screen out of the DVD player.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 231
