跳转到主内容
Philips DVP5992-F7 Power Cord Replacement
你所需要的
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: 步骤 1 中的图像 3,3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: 步骤 2 中的图像 1,2 Philips DVP5992-F7 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: 步骤 3 中的图像 1,3 Philips DVP5992-F7 Power Cord Replacement: 步骤 3 中的图像 2,3 Philips DVP5992-F7 Power Cord Replacement: 步骤 3 中的图像 3,3
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 394
