跳转到主内容
Philips DVP5992-F7 Audio Video Port Replacement
你所需要的
  1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 步骤 1 中的图像 1,3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 步骤 1 中的图像 2,3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 步骤 1 中的图像 3,3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Audio Video Port Replacement: 步骤 2 中的图像 1,2 Philips DVP5992-F7 Audio Video Port Replacement: 步骤 2 中的图像 2,2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Audio Video Port Replacement: 步骤 3 中的图像 1,3 Philips DVP5992-F7 Audio Video Port Replacement: 步骤 3 中的图像 2,3 Philips DVP5992-F7 Audio Video Port Replacement: 步骤 3 中的图像 3,3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 Audio Video Port Replacement: 步骤 4 中的图像 1,1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 Audio Video Port Replacement: 步骤 5 中的图像 1,1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 Audio Video Port Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard from the DVD player.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 302
