跳转到主内容
Philips DC320 37 Speaker Replacement
你所需要的
  1. Philips DC320 37 Speaker Replacement, Docking entertainment system: 步骤 1 中的图像 1,1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Speaker Replacement: 步骤 2 中的图像 1,1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Speaker Replacement: 步骤 4 中的图像 1,3 Philips DC320 37 Speaker Replacement: 步骤 4 中的图像 2,3 Philips DC320 37 Speaker Replacement: 步骤 4 中的图像 3,3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  6. Philips DC320 37 Speaker Replacement: 步骤 6 中的图像 1,3 Philips DC320 37 Speaker Replacement: 步骤 6 中的图像 2,3 Philips DC320 37 Speaker Replacement: 步骤 6 中的图像 3,3
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  7. Philips DC320 37 Speaker Replacement: 步骤 7 中的图像 1,1
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  8. Philips DC320 37 Speaker Replacement: 步骤 8 中的图像 1,2 Philips DC320 37 Speaker Replacement: 步骤 8 中的图像 2,2
    • Slide the speaker towards the bottom of the device to remove.
结论
Graham Rolph
于04/18/13注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G48
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 937
