简介
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
      • Electrical Connectors
      • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  7. Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  8. Separate the white suport bracket from the headphone/power electronics board.
    • Separate the white suport bracket from the headphone/power electronics board.
结论
Graham Rolph
于2013年04月18日注册
1 信誉积分
创作了2篇指南
团队
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G48
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 1,030
