跳转到主内容
Philips DC320 37 Bottom Button Circuit Board Replacement
你所需要的
  1. Philips DC320 37 Bottom Button Circuit Board Replacement, Docking entertainment system: 步骤 1 中的图像 1,1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 4 中的图像 1,3 Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 4 中的图像 2,3 Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Bottom Button Circuit Board Replacement, Bottom Button Circuit Board: 步骤 5 中的图像 1,1
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
  6. Philips DC320 37 Bottom Button Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Pull the board out from the dock
结论
Greg Lane
于04/16/13注册
39 声望
创作了4篇指南
团队
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G48
4 名成员
创作了6篇指南
一条评论
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 884
