跳转到主内容
Philips BiPAP S/T Air Filter Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
视频概述
  1. Philips BiPAP S/T Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,1
    • Disconnect the device from the power source to stop airflow.
    • To avoid electrical shock, always unplugged the power cord from the wall outlet before cleaning the device.
  2. Philips BiPAP S/T Air Filter Replacement: 步骤 2 中的图像 1,2 Philips BiPAP S/T Air Filter Replacement: 步骤 2 中的图像 2,2
    • Remove the filter from the enclosure by gently squeezing the filter in the center and pulling it away from the device.
    • Examine the filter for cleanliness and quality.
    • If the foam filter is torn, replace it. (Only Philips Respironics-supplied filters should be used as replacement filters.)
    • A dirty inlet filter may cause high operating temperatures that may affect device performance. Regularly examine the inlet filter.
  3. Philips BiPAP S/T Air Filter Replacement: 步骤 4 中的图像 1,1
    • Wash the gray foam filter in warm water with a mild detergent.
    • Rinse thoroughly to remove all detergent residue.
    • Allow the filter to air dry completely before reinstalling it.
    • Never install a wet filter into the device. You must ensure sufficient drying time.
  4. Philips BiPAP S/T Air Filter Replacement: 步骤 5 中的图像 1,1
    • Reinstall the filter.
    • To install, insert gray foam filter into the filter area.
    • A properly installed, undamaged filter is required for proper operation.
结论
Sophia James
于04/07/20注册
193 声望
撰写一个指南
团队
Cal Poly, Team S7-G3, Paton Spring 2020 Cal Poly, Team S7-G3, Paton Spring 2020 的会员
CPSU-PATON-S20S7G3
3 名成员
创作了3篇指南
2条评论
In India corona virus control in a earlier situation and now its spread in many countries again '''bipap machines''' are necessary for many peoples in this situation but you have to be careful from your side as well btw thanks for informative article.
mers - 回复
Why is there a gray blue material coming out on the output filter. It has been doing for over two years. Is it killing me. My bi pa was recalled over a year ago, when are they going to replace it ?
EDward Stone - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 23
总计 1,301
