跳转到主内容
Petzl E03 050 Headlamp Light Bulb Replacement Guide
  1. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Check For Spare Bulb: 步骤 1 中的图像 1,1
    • Check for a spare bulb in the spare bulb compartment located on the back of the battery housing (found behind the mount assembly). If no spare bulb is found in the spare bulb compartment you will need to purchase a replacement 3V incandescent bulb from a reputable retailer
  2. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Loosen the Lens Piece: 步骤 2 中的图像 1,1
    • Turn the lens piece counterclockwise (left) until it is fully extended.
  3. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lens Piece: 步骤 3 中的图像 1,1
    • Remove the lens piece by firmly pulling it away from the battery housing.
  4. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lightbulb: 步骤 4 中的图像 1,1
    • Turn the bulb counterclockwise (left) until it becomes free. Safely discard the old bulb.
  5. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Install the New Lightbulb: 步骤 5 中的图像 1,1
    • Install the new bulb by inserting it into the socket.
  6. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Rotate Replacement Light Bulb: 步骤 6 中的图像 1,1
    • Rotate the bulb clockwise (right) until it is firmly fixed in place.
  7. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Re-attach the Lens Piece: 步骤 7 中的图像 1,1
    • Press the lens piece onto the front of the battery housing.
  8. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Tighten the Lens Piece: 步骤 8 中的图像 1,1
    • Turn the lens piece clockwise (right) to the “On” position. If the light fails to illuminate after turning the lens piece to the “On” position you may have to replace the batteries.
终点
Carla
于10/19/14注册
131 声望
撰写一个指南
团队
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G10
3 名成员
创作了10篇指南
3指南评论
Ha I wonder how many people don’t even realize there’s a replacement readily available on their head! Thanks for sharing.
jmania - 回复
This was my father headlamp. Want to continue using it.. makes me feel like he is this with me
laura.odonnell52 - 回复
Is it also possible to replace the old 3v light bulb with an LED light?
bertkling - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 95
总计 5,968
