跳转到主内容
Petzl E03 050 Headlamp Battery Replacement
你所需要的
  1. Petzl E03 050 Headlamp Battery Replacement, Remove the Cover: 步骤 1 中的图像 1,1
    • Remove the back cover of the battery housing (found behind the mount assembly) by pulling the small tab on the bottom right corner.
  2. Petzl E03 050 Headlamp Battery Replacement, Remove the Old Batteries: 步骤 2 中的图像 1,1
    • Remove the old batteries by pulling outward the positive end of each battery.
  3. Petzl E03 050 Headlamp Battery Replacement, Insert the New Batteries: 步骤 3 中的图像 1,1
    • Insert the new batteries by inserting the negative end of the battery into the negative side of the battery compartment and pushing the positive end of the battery into the positive side of battery compartment.
  4. Petzl E03 050 Headlamp Battery Replacement, Reattach the Cover: 步骤 4 中的图像 1,1
    • Reattach the back cover of the battery housing by pushing in the bottom half and then pressing the rest of the cover into place.
终点
另外一个人完成了本指南。
Mike
于10/23/14注册
331 声望
创作了3篇指南
团队
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G10
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 75
总计 5,187
