跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The SmartFeeder has a rubber wheel between the top food basin and the lower metal tray. This wheel may become stuck or damaged during operation. Get a friend to help you hold the wheel housing open while you remove the wheel in Step 4.
  1. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base. Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up. Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off very easily.
  4. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  5. Flip over the SmartFeeder by using both hands. Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side. Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  6. Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section. Place the bottom piece of the device right-side up.
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  7. Remove the eight 11mm screws from the central pillar using  a Phillips #1 screwdriver.
    • Remove the eight 11mm screws from the central pillar using a Phillips #1 screwdriver.
  8. Pull apart the two sides of the central pillar at the top by using both hands. The two sides will not completely separate at the base.
    • Pull apart the two sides of the central pillar at the top by using both hands.
    • The two sides will not completely separate at the base.
    • With the two halves partially separated, pull out the rubber wheel with your hand.
    • A small black rectangular piece may fall out of the chute when the halves are partially separated. Reattach this by reaching into the chute and putting the pins from the piece into the holes on the side of the chute.
结论
另外一个人完成了本指南。
Louis Squitieri
于2018年10月08日注册
157 信誉积分
撰写一个指南
团队
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 的会员
CPSU-WHITE-F18S13G7
4 名成员
创作了5篇指南
Always nice to have a link to part so we know where to buy
David - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 33
总计 728
