跳转到主内容
Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement
你所需要的
  1. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: 步骤 1 中的图像 1,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: 步骤 1 中的图像 2,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: 步骤 1 中的图像 3,3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 2 中的图像 1,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 2 中的图像 2,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 2 中的图像 3,3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 3 中的图像 1,1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off very easily.
  4. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 4 中的图像 1,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 4 中的图像 2,3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 4 中的图像 3,3
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 5 中的图像 1,2 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 5 中的图像 2,2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 6 中的图像 1,1
    • Remove the eight 11mm screws from the central pillar using a Phillips #1 screwdriver.
  7. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 7 中的图像 1,2 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: 步骤 7 中的图像 2,2
    • Pull apart the two sides of the central pillar at the top by using both hands.
    • The two sides will not completely separate at the base.
    • With the two halves partially separated, pull out the rubber wheel with your hand.
    • A small black rectangular piece may fall out of the chute when the halves are partially separated. Reattach this by reaching into the chute and putting the pins from the piece into the holes on the side of the chute.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 的会员
CPSU-WHITE-F18S13G7
4 名成员
创作了5篇指南
一条评论
Always nice to have a link to part so we know where to buy
David - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 1,256
