跳转到主内容
Petnet SmartFeeder SF10E Battery Replacement
你所需要的
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: 步骤 1 中的图像 1,3 Petnet SmartFeeder SF10E Battery Replacement, Battery: 步骤 1 中的图像 2,3 Petnet SmartFeeder SF10E Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: 步骤 2 中的图像 1,2 Petnet SmartFeeder SF10E Battery Replacement: 步骤 2 中的图像 2,2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: 步骤 3 中的图像 1,2 Petnet SmartFeeder SF10E Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: 步骤 4 中的图像 1,2 Petnet SmartFeeder SF10E Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: 步骤 5 中的图像 1,2 Petnet SmartFeeder SF10E Battery Replacement: 步骤 5 中的图像 2,2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 的会员
CPSU-WHITE-F18S13G7
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 567
