跳转到主内容
Perfect Cooker RC301M Disassembly
你所需要的
精选文档
  1. Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: 步骤 1 中的图像 1,2 Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: 步骤 1 中的图像 2,2
    • Remove the power cord and find a clean flat surface to work at.
  2. Perfect Cooker RC301M Disassembly: 步骤 2 中的图像 1,3 Perfect Cooker RC301M Disassembly: 步骤 2 中的图像 2,3 Perfect Cooker RC301M Disassembly: 步骤 2 中的图像 3,3
    • Remove the lid by unhinging the side tabs.
    • Remove the inner pot and any other contents.
  3. Perfect Cooker RC301M Disassembly: 步骤 3 中的图像 1,3 Perfect Cooker RC301M Disassembly: 步骤 3 中的图像 2,3 Perfect Cooker RC301M Disassembly: 步骤 3 中的图像 3,3
    • Flip the device over and look for the two screws recessed underneath the device.
  4. Perfect Cooker RC301M Disassembly: 步骤 4 中的图像 1,3 Perfect Cooker RC301M Disassembly: 步骤 4 中的图像 2,3 Perfect Cooker RC301M Disassembly: 步骤 4 中的图像 3,3
    • Using a Phillips #2 screwdriver, remove the two 32.8 mm screws.
  5. Perfect Cooker RC301M Disassembly: 步骤 5 中的图像 1,1
    • Carefully lift up the bottom to reveal the wires and mechanism.
    • Make sure not to pull it up too much as it is still connected to the device body with the center metal mechanism.
  6. Perfect Cooker RC301M Disassembly: 步骤 6 中的图像 1,1
    • The center mechanism is directly in the center of the device and connects the switch to the middle
    • This part of the device raises and lowers the burner to change from the cook to warm function.
    • The two parts of the mechanism are connected by a simple metal “T-shaped” tab.
  7. Perfect Cooker RC301M Disassembly: 步骤 7 中的图像 1,3 Perfect Cooker RC301M Disassembly: 步骤 7 中的图像 2,3 Perfect Cooker RC301M Disassembly: 步骤 7 中的图像 3,3
    • Disconnect the two metal arms.
    • It can be seen that the metal tab must be bent into a “U-shape” in order to fit through the other arm of the mechanism.
    • Take the small chain nose pliers and bend each side of the “T-shaped” tab inwards.
    • Use trial and error to bend the tabs until they are able to fit through the “U-shape” cut out in the other arm.
  8. Perfect Cooker RC301M Disassembly: 步骤 8 中的图像 1,2 Perfect Cooker RC301M Disassembly: 步骤 8 中的图像 2,2
    • Separate the two parts of the devices.
    • The "U-shape" cut out can now be clearly seen.
    • The T-tab remains in the "U-shape" after slipping through the slot.
结论
附加文件
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 25
总计 593
