跳转到主内容
Pentax Optio WP Motherboard and Flash Unit Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Pentax Optio WP Motherboard and Flash Unit Replacement, Motherboard and Flash Unit: 步骤 1 中的图像 1,1
    • Remove the 4 mm black screw on the bottom right corner of the mother board.
    • The black screw may be hard to remove. Use the tweezers if necessary.
  2. Pentax Optio WP Motherboard and Flash Unit Replacement: 步骤 2 中的图像 1,1
    • With the tweezers, carefully peel back the copper ribbon that was underneath the black screw.
  3. Pentax Optio WP Motherboard and Flash Unit Replacement: 步骤 3 中的图像 1,1
    • Remove the 2.5 mm silver screw from the upper left corner of the motherboard.
  4. Pentax Optio WP Motherboard and Flash Unit Replacement: 步骤 4 中的图像 1,2 Pentax Optio WP Motherboard and Flash Unit Replacement: 步骤 4 中的图像 2,2
    • Press down on the metal plate and gently lift the motherboard up from left to right.
    • Be cautious when lifting the motherboard since there is a copper ribbon and two wires attaching the motherboard to the flash unit.
    • Reorient the camera so you are looking at the top edge with the metal plate on the right.
结论
Derek
于01/21/11注册
746 声望
创作了5篇指南
团队
Cal Poly, Team 1-13, Amido Winter 2011 Cal Poly, Team 1-13, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G13
5 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 236
