跳转到主内容
Pentax Optio WP Battery and SD Card Replacement
  1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: 步骤 1 中的图像 1,1
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Battery and SD Card Replacement: 步骤 2 中的图像 1,2 Pentax Optio WP Battery and SD Card Replacement: 步骤 2 中的图像 2,2
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
结论
Olivia Nixon
于01/16/11注册
429 声望
创作了4篇指南
团队
Cal Poly, Team 1-13, Amido Winter 2011 Cal Poly, Team 1-13, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G13
5 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 3,997
