跳转到主内容
Pentax Optio WG-3 GPS Shutter and Power Button Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Shutter and Power Button Replacement, Shutter and Power Button: 步骤 1 中的图像 1,1
    • Peel the lining back on the top of the camera.
    • The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: 步骤 2 中的图像 1,1
    • Using tweezers pull straight up to remove the 2 rubber button toppers
  3. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove the 3, 2 mm screws under the rubber buttons.
  4. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: 步骤 4 中的图像 1,1
    • Replace the shutter/power button or button component.
结论
Allison Merdian
于03/05/15注册
422 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 616
