跳转到主内容
Pentax Optio WG-3 GPS Screen Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Screen Replacement, Screen: 步骤 1 中的图像 1,3 Pentax Optio WG-3 GPS Screen Replacement, Screen: 步骤 1 中的图像 2,3 Pentax Optio WG-3 GPS Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Using a Philips screwdriver (PH00), remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Screen Replacement: 步骤 2 中的图像 1,1
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Be aware of a few flex cables that connect the mother board to the screen.
    • Open the devices slowly and disconnect the flex cables. When the flex cables have been disconnected you can take the device apart.
  3. Pentax Optio WG-3 GPS Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 4, 2 mm screws from each corner of the metal screen cover.
    • The larger metal piece is the side the screen is on.
    • Be aware of a detachable metal separator under the top left screw.
  4. Pentax Optio WG-3 GPS Screen Replacement: 步骤 4 中的图像 1,2 Pentax Optio WG-3 GPS Screen Replacement: 步骤 4 中的图像 2,2
    • Detach flex cable and replace screen component.
结论
另外一个人完成了本指南。
Allison Merdian
于03/05/15注册
422 声望
创作了4篇指南
团队
一条评论
Any idea where you can buy the replacement screen from? I’m not having any luck finding one. Thank you!
jztmail-1989 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,716
