跳转到主内容
Pentax Optio WG-3 GPS Menu Button Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 步骤 1 中的图像 1,3 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 步骤 1 中的图像 2,3 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device so you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Menu Button Replacement: 步骤 2 中的图像 1,1
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Open the device slowly and be aware of a few flex cables that connect the mother board to the screen. These will have to be carefully disconnected before the top part is removed.
  3. Pentax Optio WG-3 GPS Menu Button Replacement: 步骤 3 中的图像 1,1
    • Remove the 8, 2 mm screws from each corner of the metal button pad cover.
    • Using tweezers remove the metal cover.
    • The smaller Metal square piece on the device.
  4. Pentax Optio WG-3 GPS Menu Button Replacement: 步骤 4 中的图像 1,1
    • Remove the 1, 2 mm screw near the edge of the device.
  5. Pentax Optio WG-3 GPS Menu Button Replacement: 步骤 5 中的图像 1,1
    • Now using tweezers, remove the menu button from its place.
    • After removing the button you can replace the entire component.
结论
Allison Merdian
于03/05/15注册
422 声望
创作了4篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 583
