跳转到主内容
Pentax Optio WG-3 GPS Main Button Pad Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Main Button Pad Replacement, Main Button Pad: 步骤 1 中的图像 1,3 Pentax Optio WG-3 GPS Main Button Pad Replacement, Main Button Pad: 步骤 1 中的图像 2,3 Pentax Optio WG-3 GPS Main Button Pad Replacement, Main Button Pad: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a Philips head screwdriver, remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Main Button Pad Replacement: 步骤 2 中的图像 1,1
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Be aware of a few flex cables that connect the mother board to the screen.
    • Open the devices slowly and disconnect the flex cables. When the flex cables have been disconnected you can take the device apart.
  3. Pentax Optio WG-3 GPS Main Button Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the 6, 2 mm screws from each corner of the metal button pad cover.
    • Using tweezers remove the metal cover.
  4. Pentax Optio WG-3 GPS Main Button Pad Replacement: 步骤 4 中的图像 1,1
    • Disconnect the flex cables and replace the menu pad button or button component.
结论
Allison Merdian
于03/05/15注册
422 声望
创作了4篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 715
