跳转到主内容
Pentax Optio WG-3 GPS Lens Assembly Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: 步骤 1 中的图像 1,1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 2 中的图像 1,1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 5 中的图像 1,1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 6 中的图像 1,1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: 步骤 7 中的图像 1,1
    • Gently slide the lens piece to the right, remove the tape and take it out.
结论
Garrett Rose
于03/31/22注册
373 声望
创作了2篇指南
团队
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 210
