跳转到主内容
Pentax Optio WG-3 GPS Flash Replacement
你所需要的
  1. Pentax Optio WG-3 GPS Flash Replacement, Flash: 步骤 1 中的图像 1,1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Flash Replacement: 步骤 2 中的图像 1,1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Flash Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Flash Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Flash Replacement: 步骤 5 中的图像 1,1
    • Upon removing the flash, there is a 2 mm screw that needs to be removed.
  6. Pentax Optio WG-3 GPS Flash Replacement: 步骤 6 中的图像 1,1
    • Remove the ribbon cable that attaches the flash from the circuitry.
  7. Pentax Optio WG-3 GPS Flash Replacement: 步骤 7 中的图像 1,1
    • Remove the three 2 mm Phillips #000 screws from the left side of the circuitry.
    • These screws attach the circuit board to the shell of the camera.
    • Remove the circuitry from the front side of the camera
  8. Pentax Optio WG-3 GPS Flash Replacement: 步骤 8 中的图像 1,1
    • Find and remove the camera battery.
  9. Pentax Optio WG-3 GPS Flash Replacement: 步骤 9 中的图像 1,1
    • Remove the final two 2 mm Phillips #000 screws from the front side of the circuitry.
  10. Pentax Optio WG-3 GPS Flash Replacement: 步骤 10 中的图像 1,1
    • Pull the black front panel away from the circuitry.
    • The black panel is attached to the flash and is now ready to be removed and replaced.
    • The sensor is enclosed in the white case.
结论
Cassandra Stec
于03/14/22注册
181 声望
撰写一个指南
团队
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S3G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 150
