跳转到主内容
Pentax Optio S4i Front and Back Cover Replacement
你所需要的
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: 步骤 1 中的图像 1,2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: 步骤 3 中的图像 1,2 Pentax Optio S4i Front and Back Cover Replacement: 步骤 3 中的图像 2,2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: 步骤 4 中的图像 1,3 Pentax Optio S4i Front and Back Cover Replacement: 步骤 4 中的图像 2,3 Pentax Optio S4i Front and Back Cover Replacement: 步骤 4 中的图像 3,3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: 步骤 5 中的图像 1,2 Pentax Optio S4i Front and Back Cover Replacement: 步骤 5 中的图像 2,2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
结论
另外一个人完成了本指南。
Nicole Wong
于01/30/11注册
329 声望
创作了3篇指南
团队
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G29
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,196
