跳转到主内容
Penn-Plax Cascade 20 Power Filter Impeller Replacement
你所需要的
  1. Penn-Plax Cascade 20 Power Filter Impeller Replacement, Impeller: 步骤 1 中的图像 1,1
    • Start by placing filter system on your workstation of choice.
  2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 2 中的图像 1,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 2 中的图像 2,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 2 中的图像 3,3
    • Remove all detachable pieces from the filter. This includes the lid, pipe, and filter media.
  3. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 3 中的图像 1,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 3 中的图像 2,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 3 中的图像 3,3
    • Take your filter and place it upside down.
    • Place your hand on the motor. Grab it firmly and turn it clockwise for a quarter turn. When the turn is complete, it should look like the second picture.
    • Pull the motor up and out from the filter chassis.
    • The motor should be able to be pulled off with ease.
  4. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 4 中的图像 1,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 4 中的图像 2,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 4 中的图像 3,3
    • Take your index finger and thumb and firmly grip one of the impeller blades.
    • Pull the impeller up and out of the motor shaft.
    • You should feel mild resistance because the impeller is secured via magnet.
  5. Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 5 中的图像 1,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 5 中的图像 2,3 Penn-Plax Cascade 20 Power Filter Impeller Replacement: 步骤 5 中的图像 3,3
    • To install a new impeller, grab it by the fins and place it back into the motor shaft hole.
    • Push the new impeller in and make sure it is connected to the magnetic seal. This can be checked by flipping the motor upside down and seeing if the impeller falls out.
结论
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
另外一个人完成了本指南。
Danny Vo
于03/06/22注册
145 声望
撰写一个指南
团队
UM-KIM-S22SM50G2 UM-KIM-S22SM50G2 的会员
Community
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 33
总计 298
