简介
Following the steps in this guide will demonstrate how to fix a broken or damaged impeller in a Penn-Plax Cascade 20 Power Filter. A broken or damaged impeller may cause the filter to malfunction and water to flow inefficiently. The filter system and the impeller are relatively small, so being aware of where the parts go is important.
The filter system should be unplugged and free of water and dirt before starting. There are no special skills required.
This guide will help you replace your impeller in no time.
你所需要的
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
另外一个人完成了本指南。
