跳转到主内容
Penguin FZ-8 28” Tower Fan Blade Replacement
你所需要的
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: 步骤 1 中的图像 1,1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 2 中的图像 1,3 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 2 中的图像 2,3 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 2 中的图像 3,3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 3 中的图像 1,2 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 3 中的图像 2,2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 4 中的图像 1,2 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 5 中的图像 1,2 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 5 中的图像 2,2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 6 中的图像 1,2 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 6 中的图像 2,2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 7 中的图像 1,1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 8 中的图像 1,2 Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 8 中的图像 2,2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: 步骤 9 中的图像 1,1
    • Remove the fan blade from the device and clean it off before reassembling your device.
结论
Ethan
于03/22/21注册
169 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G4, Riel Spring 2021 UMass Dartmouth, Team S2-G4, Riel Spring 2021 的会员
UMASSD-RIEL-S21S2G4
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 52
总计 957
