跳转到主内容
Pebble Time Screen Replacement
你所需要的
  1. Pebble Time Screen Replacement, Screen Cover: 步骤 1 中的图像 1,1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: 步骤 2 中的图像 1,2 Pebble Time Screen Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: 步骤 3 中的图像 1,1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: 步骤 6 中的图像 1,1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: 步骤 7 中的图像 1,3 Pebble Time Screen Replacement: 步骤 7 中的图像 2,3 Pebble Time Screen Replacement: 步骤 7 中的图像 3,3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
结论
另外一个人完成了本指南。
Saud Al-Malki
于02/19/17注册
110 声望
撰写一个指南
团队
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G3
4 名成员
创作了7篇指南
3条评论
Where can I buy the display replacement?
ulises - 回复
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - 回复
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 19
总计 3,188
