跳转到主内容
Pebble Time Round Glass Screen Protector Replacement
你所需要的
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: 步骤 1 中的图像 1,1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: 步骤 2 中的图像 1,1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
结论
Kyle
于11/01/21注册
85 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G5
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 543
