跳转到主内容
Pebble Time Circuit Board Replacement
你所需要的
  1. Pebble Time Circuit Board Replacement, Screen Cover: 步骤 1 中的图像 1,1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: 步骤 2 中的图像 1,2 Pebble Time Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: 步骤 5 中的图像 1,1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: 步骤 7 中的图像 1,3 Pebble Time Circuit Board Replacement: 步骤 7 中的图像 2,3 Pebble Time Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: 步骤 8 中的图像 1,1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: 步骤 10 中的图像 1,3 Pebble Time Circuit Board Replacement: 步骤 10 中的图像 2,3 Pebble Time Circuit Board Replacement: 步骤 10 中的图像 3,3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: 步骤 11 中的图像 1,1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: 步骤 12 中的图像 1,2 Pebble Time Circuit Board Replacement: 步骤 12 中的图像 2,2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
结论
Nicolas Hempe
于02/15/17注册
1,444 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 12
总计 836
