跳转到主内容
加入维修社区 - 创建账户
Pebble Time Battery Replacement
你所需要的
  1. Pebble Time Battery Replacement, Screen Cover: 步骤 1 中的图像 1,1
    • Lay the watch flat on your workstation.
  2. Pebble Time Battery Replacement: 步骤 2 中的图像 1,2 Pebble Time Battery Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Battery Replacement: 步骤 3 中的图像 1,1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Battery Replacement, Screen: 步骤 5 中的图像 1,1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Battery Replacement: 步骤 6 中的图像 1,1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Battery Replacement: 步骤 7 中的图像 1,3 Pebble Time Battery Replacement: 步骤 7 中的图像 2,3 Pebble Time Battery Replacement: 步骤 7 中的图像 3,3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Battery Replacement, Circuit Board: 步骤 8 中的图像 1,1
    • Keep the watch flat on your workstation.
  9. Pebble Time Battery Replacement: 步骤 9 中的图像 1,1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Battery Replacement: 步骤 10 中的图像 1,3 Pebble Time Battery Replacement: 步骤 10 中的图像 2,3 Pebble Time Battery Replacement: 步骤 10 中的图像 3,3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Battery Replacement: 步骤 12 中的图像 1,2 Pebble Time Battery Replacement: 步骤 12 中的图像 2,2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Battery Replacement, Battery: 步骤 13 中的图像 1,1
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Battery Replacement: 步骤 14 中的图像 1,2 Pebble Time Battery Replacement: 步骤 14 中的图像 2,2
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Battery Replacement: 步骤 15 中的图像 1,2 Pebble Time Battery Replacement: 步骤 15 中的图像 2,2
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
结论
34等其他人完成本指南。
Nicolas Hempe
于02/15/17注册
1,492 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G3
4 名成员
创作了10篇指南
12指南评论
Where did you purchase the replacement battery?
Dimas Caparros - 回复
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - 回复
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
Shannon Oswald - 回复
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 107
过去 30 天: 358
总计 25,988
