跳转到主内容
Pebble Steel failure of screen
  1. Pebble Steel failure of screen, Disassemble Strap: 步骤 1 中的图像 1,1
    • The first step is to remove the strap. To do this, we will use a 1.5mm flathead screwdriver.
  2. Pebble Steel failure of screen, Remove back cover: 步骤 2 中的图像 1,2 Pebble Steel failure of screen, Remove back cover: 步骤 2 中的图像 2,2
    • We will disassemble the cover of the clock using a screwdriver T-5, and being careful with the rubber gasket that has, we will remove the metallic cover.
  3. Pebble Steel failure of screen, Find and cut a soft rubber: 步骤 3 中的图像 1,2 Pebble Steel failure of screen, Find and cut a soft rubber: 步骤 3 中的图像 2,2
    • In this step we will look for a dissipative silicone of those that carry the laptops for the microprocessor. If you do not have it, you could use a piece of soft rubber that does not exceed 0.65mm thick.
  4. Pebble Steel failure of screen, Place rubber: 步骤 4 中的图像 1,2 Pebble Steel failure of screen, Place rubber: 步骤 4 中的图像 2,2
    • We will place this rubber in the lower right corner of the watch, on the vibrator and the connector of the screen. The golden connector on the left must be left free since it makes contact with the lid.
  5. Pebble Steel failure of screen, Close and READY !!!!: 步骤 5 中的图像 1,1
    • Finally we assemble the clock reversing the steps. '++ It is important when placing the cover to put first the two screws above and then the two screws below.' (This forces the entire internal chassis, thus exerting a pressure on the rubber contact of the screen.)
结论
For reassembling your device, follow these instructions in the reverse order.
3等其他人完成本指南。
由衷感谢以下译者:
es en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Marcos Garcia
于03/29/16注册
175 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 51
总计 1,590
