跳转到主内容
加入维修社区 - 创建账户
Pebble Steel Zebra Strip Replacement
你所需要的
  1. Pebble Steel Zebra Strip Replacement, Opening the watch: 步骤 1 中的图像 1,1
    • The Pebble Steel uses four Torx T3 screws to hold the rear of the watch housing on. First we'll remove all four screws.
  2. Pebble Steel Zebra Strip Replacement, Removing the Backplate: 步骤 2 中的图像 1,1
    • Gently lift one corner off of the back off of the watch. Slide a credit card, or a piece of paper through to cut the adhesive on the vibrator motor. (It's adhered to the back of the watch. Not performing this step risks lifting traces on the motherboard.)
    • The back of the watch is off now. Be careful with the waterproofing o-ring! sometimes it comes off.
  3. Pebble Steel Zebra Strip Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to grab the clip on each corner. Individually apply pressure inward while lifting to release each clip, but be careful not to damage the buttons ribbon cable. You should feel the internal frame release while doing this.
    • Lift the frame out of the pebble from the side with 3 buttons. (This will avoid damaging the internal charging contacts).
  4. Pebble Steel Zebra Strip Replacement: 步骤 4 中的图像 1,2 Pebble Steel Zebra Strip Replacement: 步骤 4 中的图像 2,2
    • The Zebra strip can stick to either the screen or the motherboard. Remove it with a pair of tweezers.
  5. Pebble Steel Zebra Strip Replacement: 步骤 5 中的图像 1,3 Pebble Steel Zebra Strip Replacement: 步骤 5 中的图像 2,3 Pebble Steel Zebra Strip Replacement: 步骤 5 中的图像 3,3
    • The new zebra strip will be slightly "taller" than the existing one. This is intentional. Cutting it to be slightly "longer" than the original is fine as well. (The idea is to compress the new strip slightly.)
    • You can now re-insert the zebra strip from the motherboard side.
    • Insert the internal frame back into the Pebble's shell. (Zebra strip side/Backlight side down). At this point, you can screw the backplate onto the watch - try to preserve the oring/gasket integrity when doing so to ensure your Pebble remains water-tight.
结论
danielelliott1
于11/29/13注册
355 声望
撰写一个指南
3指南评论
Can you we get the dimensions for the Zebra Strip please?
Orlando Brown - 回复
Yeah... I'm going to improve this tutorial - I didn't realize anyone actually used it / looked at it - but it's being linked to on /r/pebble.
danielelliott1 - 回复
With the new core watches announced, now would be a great time to update this if you can ;-)
Max -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 119
总计 3,794
