跳转到主内容
Pebble Steel Vibration Motor Replacement
你所需要的
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: 步骤 1 中的图像 1,3 Pebble Steel Vibration Motor Replacement, Internal Hardware: 步骤 1 中的图像 2,3 Pebble Steel Vibration Motor Replacement, Internal Hardware: 步骤 1 中的图像 3,3
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Vibration Motor Replacement: 步骤 2 中的图像 1,2 Pebble Steel Vibration Motor Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: 步骤 3 中的图像 1,1
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
  4. Pebble Steel Vibration Motor Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
结论
另外一个人完成了本指南。
Orlandria Heggs
于10/01/15注册
545 声望
创作了3篇指南
团队
USF Tampa, Team 1-7, Leahy Fall 2015 USF Tampa, Team 1-7, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G7
3 名成员
创作了7篇指南
2指南评论
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - 回复
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 3,505
