简介
I go step by step through how to replace an input jack on the Peavy XM4 Amp/Mixer
  1. There are two screws at the top and two at the bottom
    • There are two screws at the top and two at the bottom
  2. All of the dials have a rubber cover and a nut, these need to be removed from all of the dials.  The Jack inputs also have a nut holding them in place, remove these also.
    • All of the dials have a rubber cover and a nut, these need to be removed from all of the dials. The Jack inputs also have a nut holding them in place, remove these also.
    • Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
    • Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
    • Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
结论
Josh Walford
于2018年01月12日注册
157 信誉积分
撰写一个指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 11
