跳转到主内容
Patching a 125 2 stroke fuel tank
你所需要的
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: 步骤 1 中的图像 1,1
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
  2. Patching a 125 2 stroke fuel tank: 步骤 2 中的图像 1,1
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
  3. Patching a 125 2 stroke fuel tank: 步骤 3 中的图像 1,1
    • Make sure that the ointment is spread thickly over the hole.
  4. Patching a 125 2 stroke fuel tank: 步骤 4 中的图像 1,1
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
  5. Patching a 125 2 stroke fuel tank: 步骤 6 中的图像 1,1
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
  6. Patching a 125 2 stroke fuel tank: 步骤 7 中的图像 1,1
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    • Once patch is dry put fuel in the tank.
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    • If there are leaks scrape off patch and repeat process.
  7. Patching a 125 2 stroke fuel tank: 步骤 11 中的图像 1,1
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
结论
3等其他人完成本指南。
Andrew
于02/17/15注册
1,387 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 56
总计 1,842
