跳转到主内容
Patching Surfboard Fiberglass
你所需要的
  1. Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: 步骤 1 中的图像 1,3 Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: 步骤 1 中的图像 2,3 Patching Surfboard Fiberglass, Patching Surfboard Fiberglass: 步骤 1 中的图像 3,3
    • So, to begin, we need a nice clean working area. My place is small so I used my patio set (not the best idea though, as my wife flipped when she found out I was using toxic chemicals where we occasionally eat, just beware.)
    • Things you will need:
    • Surfboard with dings
    • Cleaning tools: wax comb, rag, and Gloves!!!
    • Resin, Q-Cell Filler, Hardener, Fiberglass Cloth
    • Mixing cup, stirring stick,Transparency
    • Sand paper: 1 rough grit and 1 fine grit
    • Starbucks (optional)
  2. Patching Surfboard Fiberglass: 步骤 2 中的图像 1,3 Patching Surfboard Fiberglass: 步骤 2 中的图像 2,3 Patching Surfboard Fiberglass: 步骤 2 中的图像 3,3
    • Next, you need to identify the dinged areas and figure out which method you prefer to use. I used cloth repair on the bigger ones (and the rail ones) and then the sun cure on the small ones (because I have heard it works well enough on small stuff).
  3. Patching Surfboard Fiberglass: 步骤 3 中的图像 1,3 Patching Surfboard Fiberglass: 步骤 3 中的图像 2,3 Patching Surfboard Fiberglass: 步骤 3 中的图像 3,3
    • Now we need to clean the dinged area of all the wax and fiberglass flakes.
    • Grab your comb and scrape any wax from around the area to be repaired.
    • Sand down, approximately 1/4", till you have a nice smooth surface.
    • Cut a small groove (in the direction of the ding) to give the repair mixture somewhere to seep into.
  4. Patching Surfboard Fiberglass: 步骤 4 中的图像 1,3 Patching Surfboard Fiberglass: 步骤 4 中的图像 2,3 Patching Surfboard Fiberglass: 步骤 4 中的图像 3,3
    • Now we come to the mixing process.
    • First figure how much resin you are going to need to adequately cover the cloth piece with a little to spare to pre-dab the dinged area.
    • Add Filler, it helps to make the solution less watery and more workable
    • Then add the hardener; you only need a little and it really depends on the temp. Your box should say what is appropriate for your particular weather.
  5. Patching Surfboard Fiberglass: 步骤 5 中的图像 1,2 Patching Surfboard Fiberglass: 步骤 5 中的图像 2,2
    • Mixing Process (Continued)
    • Put the fiberglass cloth that you cut into the mixture.
    • Stir the cloth in slowly to cover the cloth with mixture without causing air bubbles.
  6. Patching Surfboard Fiberglass: 步骤 6 中的图像 1,3 Patching Surfboard Fiberglass: 步骤 6 中的图像 2,3 Patching Surfboard Fiberglass: 步骤 6 中的图像 3,3
    • Application Process:
    • Pre-dab the area with some of the solution, if there is a chunk of the fiberglass gone, use the solution generously to fill void.
    • Spread the soaked fiberglass cloth over the dinged area and smooth it out with your fingers.
    • Use the transparency to spread the cloth evenly, working out any noticeable bubbles.
  7. Patching Surfboard Fiberglass: 步骤 7 中的图像 1,2 Patching Surfboard Fiberglass: 步骤 7 中的图像 2,2
    • Application Process (Continued)
    • Hold the transparency in place (be aware that it will not stay put).
    • Use tape (scotch, masking, painters) to secure the edges and make sure the transparency is held down tight
    • Curing and Finishup:
    • Let the mixture cure.
    • It should take, depending on your weather, about 1 hour or so to dry completely.
    • Don't remove the transparency until dry.
    • Once dry, remove the transparency and use a fine sand paper to even out any new bumps from the new fiberglass surface.
    • Then, voila! your board should be back to working order. Get out there and this time try to be more careful on the trip back to the car. ;)
结论
3等其他人完成本指南。
Eric Doster
于11/10/10注册
4,548 声望
创作了2篇指南
1指南评论
You forgot step 0 - choose a well-ventilated area (like the outdoors) before opening those aromatic chemical bottles.
Bote Man - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 29,259
