跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Patch your Patagonia Nano Puff ® Jacket with Repair Tape
你所需要的
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 1 中的图像 1,1
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 2 中的图像 1,3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 2 中的图像 2,3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 2 中的图像 3,3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 3 中的图像 1,2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 3 中的图像 2,2
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 4 中的图像 1,3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 4 中的图像 2,3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 4 中的图像 3,3
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 5 中的图像 1,2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 5 中的图像 2,2
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 6 中的图像 1,2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: 步骤 6 中的图像 2,2
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
终点
9等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,012 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,767篇指南
2条评论
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - 回复
This is really helpful, thanks.
James
James Riley - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 165
总计 45,293
