跳转到主内容
Patch an Insulated Jacket with Repair Tape
你所需要的
  1. Patch an Insulated Jacket with Repair Tape, Assess the damage: 步骤 1 中的图像 1,2 Patch an Insulated Jacket with Repair Tape, Assess the damage: 步骤 1 中的图像 2,2
    • Locate the hole.
    • Don't pull out any emerging feathers! Use a finger or pointed tool to push the feathers back inside the hole.
    • If a feather is emerging, but there isn't a tear in the fabric, follow this guide to pull feathers back into a down jacket.
  2. Patch an Insulated Jacket with Repair Tape, Clean the area: 步骤 2 中的图像 1,2 Patch an Insulated Jacket with Repair Tape, Clean the area: 步骤 2 中的图像 2,2
    • Remove any old tape or home repairs.
    • Use rubbing alcohol and a cotton ball to clean the area and remove any tape residue, dirt, and grime.
    • Let the jacket dry completely.
    • The area must be completely dry before applying the Tenacious Tape® patch.
    • Optionally, use an adhesive eraser to remove any stubborn duct tape residue.
  3. Patch an Insulated Jacket with Repair Tape, Cut out the patch: 步骤 3 中的图像 1,3 Patch an Insulated Jacket with Repair Tape, Cut out the patch: 步骤 3 中的图像 2,3 Patch an Insulated Jacket with Repair Tape, Cut out the patch: 步骤 3 中的图像 3,3
    • Use sharp scissors to cut a shape out of the Tenacious Tape® that's large enough to cover the hole and overlap it by at least half an inch (~13 mm) all the way around.
    • Round the corners of the patch because sharp edges tend to get caught and peel up.
    • Check that the patch is cut to the right size.
    • Multiple patches can be overlapped to cover a large tear or a unique shape, like an L. Ensure each patch overlaps by at least half an inch (~13 mm).
  4. Patch an Insulated Jacket with Repair Tape, Apply the patch: 步骤 4 中的图像 1,3 Patch an Insulated Jacket with Repair Tape, Apply the patch: 步骤 4 中的图像 2,3 Patch an Insulated Jacket with Repair Tape, Apply the patch: 步骤 4 中的图像 3,3
    • Check again that the cut patch is the right size for the hole.
    • Peel off the backing and carefully apply the patch over the hole, making sure to keep fingers clear of the sticky back of the patch.
    • Use tweezers to aid in peeling the backing off of smaller patches.
    • Use your fingers to smooth out any bubbles and apply pressure to the patch.
    • If the hole goes all the way through the jacket, repeat this process to place a piece of tape on the other side.
    • GARMENT CARE: Wait 24 hours for the glue on the patch to cure before putting it through a laundry cycle, otherwise the tape will fall off in the washing machine.
    • INSULATION TYPES: Be mindful of the type of insulation when patching. A down jacket with a large tear will require special care to save as many feathers from escaping as possible. Synthetic insulation is more forgiving and emerging pieces can be snipped away.
    • ALTERNATIVE REPAIRS: This repair is a great for those in a pinch (a hole in a down jacket in the middle of winter!). While it's not a permanent repair, it can last for up to 60 washes if applied properly.
终点
25等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,745 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,457篇指南
11条评论
I have now put four or five tenacious tape patches on my son's down sweater (9 year old are tough in VT). But now it is very dirty. Can I wash it like I would if it didn't have the tenacious tape - or do i need to do something different?
Hylah - 回复
Hi Hylah, Yes you can wash your jacket and if the patches are starting to peel a little after 7 years you have some options. 1) Contact Patagonia Burlington Store and ask for some more patches, each store has a variety of patches, zipper sliders, Zipper pulls, snaps, buttons to help with easy repairs. 2) Send it to us for Repair, you could take it to the store or start the process on-line . https://www.patagonia.com/returns.html
Holes are not warranty but due to wear and tear, we will repair it for you no problem. Our goal is to keep product in use as long as possible. After they have reached there end of life use, we can recycle it for you and then you can invest in another long lasting durable product. Please check out this link for additional questions. https://help.patagonia.com/s/article/Rep...
Marty Chapman -
its water proof so i guess it can be washed
sheilaym1 - 回复
Hi Sheilaym 1, Everything we make can be washed, Cold water Low tumble dry. It's good to wash your shells every once in a while to remove dirt and oils.
Marty Chapman -
I've found super glue works pretty well and doesn't show the down.
Patrick Marcott - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 222
过去 30 天: 836
总计 379,924
