跳转到主内容
Patagonia Transport Roller Telescoping Handle Replacement
你所需要的
  1. Patagonia Transport Roller Telescoping Handle Replacement, Telescoping Handle: 步骤 1 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement, Telescoping Handle: 步骤 1 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement, Telescoping Handle: 步骤 1 中的图像 3,3
    • Lay your Transport Roller on its back on a table.
    • Unzip the main compartment.
  2. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 2 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 2 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 2 中的图像 3,3
    • Flip open the main compartment of your bag.
  3. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 3 中的图像 1,2 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 3 中的图像 2,2
    • Unbuckle the internal compression straps.
  4. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 4 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 4 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 4 中的图像 3,3
    • Unzip the the zipper in the gray inner lining of the bag, opening the lining as you go.
  5. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 5 中的图像 1,2 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 5 中的图像 2,2
    • Remove the two Phillips #1 screws from the retaining bracket at the bottom of the bag.
    • These screws are approximately 2 cm in length.
  6. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 6 中的图像 1,2 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 6 中的图像 2,2
    • Remove the five Phillips #1 screws from the retaining bracket at the top of the bag.
    • These five screws are 1.5 cm in length, visibly shorter than the screws removed from the bottom retaining bracket.
  7. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 7 中的图像 1,1
    • Remove the black plastic retaining bracket from the top of the frame.
  8. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 8 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 8 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 8 中的图像 3,3
    • Using your thumb, depress the button on the telescoping handle.
    • With the button depressed, extend the handle by pulling away from the bag.
  9. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 9 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 9 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 9 中的图像 3,3
    • Turn the bag over so that the back is facing up.
    • Remove the telescoping handle assembly by pulling it out of the top of the bag.
    • This step may take some force. It may help to push down on the back of the bag while pulling up on the outer edge of the plastic handle guard so the screw anchors can move up and out of the holes in the hard backing.
  10. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 10 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 10 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 10 中的图像 3,3
    • If you are having trouble with your handle, check the pins inside the bag.
    • When you depress the button on the handle, the two pins on the sides of the handle should retract, freeing the handle to slide.
    • If either pin is not retracting when the button on the handle is depressed, push the pin into the hole using your finger or another thin object such as a pencil or screwdriver.
  11. Patagonia Transport Roller Telescoping Handle Replacement: 步骤 11 中的图像 1,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 11 中的图像 2,3 Patagonia Transport Roller Telescoping Handle Replacement: 步骤 11 中的图像 3,3
    • With the pin depressed, pull the handle to extend it from the bag.
结论
To reassemble your luggage, follow these instructions starting with Step 9. You’ll be working backwards now from that point in the guide, following the steps in reverse order.
Marty Rippens
于09/18/15注册
15,913 声望
创作了2篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,767篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 22
总计 1,471
