跳转到主内容
Parrot Skycontroller 2 Joystick Replacement
你所需要的
  1. Parrot Skycontroller 2 Joystick Replacement, Battery: 步骤 1 中的图像 1,3 Parrot Skycontroller 2 Joystick Replacement, Battery: 步骤 1 中的图像 2,3 Parrot Skycontroller 2 Joystick Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip your controller face down.
  2. Parrot Skycontroller 2 Joystick Replacement: 步骤 2 中的图像 1,1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Joystick Replacement: 步骤 3 中的图像 1,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 3 中的图像 2,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Joystick Replacement: 步骤 4 中的图像 1,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 4 中的图像 2,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 4 中的图像 3,3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 Joystick Replacement: 步骤 5 中的图像 1,2 Parrot Skycontroller 2 Joystick Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
  6. Parrot Skycontroller 2 Joystick Replacement, Joystick: 步骤 6 中的图像 1,1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
  7. Parrot Skycontroller 2 Joystick Replacement: 步骤 7 中的图像 1,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 7 中的图像 2,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 7 中的图像 3,3
    • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Joystick Replacement: 步骤 8 中的图像 1,1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Joystick Replacement: 步骤 9 中的图像 1,1
    • Remove the top plate by pushing out on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Joystick Replacement: 步骤 10 中的图像 1,2 Parrot Skycontroller 2 Joystick Replacement: 步骤 10 中的图像 2,2
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
  11. Parrot Skycontroller 2 Joystick Replacement: 步骤 11 中的图像 1,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 11 中的图像 2,3 Parrot Skycontroller 2 Joystick Replacement: 步骤 11 中的图像 3,3
    • Firmly grasp the end of either joystick.
    • Pull the joystick up and out while grasping the other side of the controller.
    • Once both joysticks have been removed, this is what it should look like.
    • Some force may be needed to remove the joysticks.
    • Repeat this process for the other side as well.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 546
