跳转到主内容
Parrot Hydrofoil Orak Battery Replacement
你所需要的
  1. Parrot Hydrofoil Orak Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the device so that the front of the boat chasis is facing to your right.
  2. Parrot Hydrofoil Orak Battery Replacement: 步骤 2 中的图像 1,3 Parrot Hydrofoil Orak Battery Replacement: 步骤 2 中的图像 2,3 Parrot Hydrofoil Orak Battery Replacement: 步骤 2 中的图像 3,3
    • Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder.
  3. Parrot Hydrofoil Orak Battery Replacement: 步骤 3 中的图像 1,2 Parrot Hydrofoil Orak Battery Replacement: 步骤 3 中的图像 2,2
    • Insert your plastic opening tool in between the tab with the arrow on it and the battery below it.
    • Pry the tool upwards to disengage the battery.
    • You can disengage the battery with your finger rather than an opening tool, although it takes quite a bit of force and you may need strong nails.
  4. Parrot Hydrofoil Orak Battery Replacement: 步骤 4 中的图像 1,1
    • Pull the battery fully out using your fingers.
结论
Matt Sterling
于10/06/16注册
183 声望
撰写一个指南
团队
Cal Poly, Team 20-2, Livingston Fall 2016 Cal Poly, Team 20-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 482
