简介
This guide will walk you through steps to replace your joystick.
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Four 0.9mm T6 screws
Two 0.1mm T6 screws
Flip the Flypad over.
Remove the six screws using a T6 screwdriver.
Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
Use Ph0 tool to remove the screws holding the motherboard in place.
Gently remove the motherboard from the front plate.
2条评论
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - 回复
