跳转到主内容
Parrot FLYPAD Buttons Replacement
你所需要的
  1. Parrot FLYPAD Buttons Replacement, Buttons: 步骤 1 中的图像 1,2 Parrot FLYPAD Buttons Replacement, Buttons: 步骤 1 中的图像 2,2
    • Position the controller so the back is facing up.
    • Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Buttons Replacement: 步骤 2 中的图像 1,2 Parrot FLYPAD Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the foam adhesive that connects the front plate to the motherboard
    • The buttons (L1,R1) may fall out. Set aside to replace during reassembly.
    • Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
    • Remove the motherboard from the front plate.
  3. Parrot FLYPAD Buttons Replacement: 步骤 3 中的图像 1,3 Parrot FLYPAD Buttons Replacement: 步骤 3 中的图像 2,3 Parrot FLYPAD Buttons Replacement: 步骤 3 中的图像 3,3
    • Remove the buttons from the front plate of the fly pad and replace as needed.
    • Hold the front plate of the fly pad facing downwards to prevent buttons from falling out.
    • Make sure the text on buttons L1 and R1 correctly line up with L2 and R2 when reassembling the device.
结论
2等其他人完成本指南。
HUY NGUYEN
于04/10/17注册
376 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G5, Liner Spring 2017 UW Tacoma, Team S3-G5, Liner Spring 2017 的会员
UWT-LINER-S17S3G5
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 541
