跳转到主内容
加入维修社区 - 创建账户
Parrot FLYPAD Battery Replacement
你所需要的
  1. Parrot FLYPAD Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: 步骤 2 中的图像 1,1
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: 步骤 3 中的图像 1,1
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: 步骤 4 中的图像 1,1
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: 步骤 5 中的图像 1,1
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
结论
另外一个人完成了本指南。
HUY NGUYEN
于04/10/17注册
376 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G5, Liner Spring 2017 UW Tacoma, Team S3-G5, Liner Spring 2017 的会员
UWT-LINER-S17S3G5
5 名成员
创作了3篇指南
3指南评论
Where did I get a new battery? Can’t find one.
Randy - 回复 分享
Sorry where do I get a new parrot flypad battery. From Randy
Randy - 回复 分享
where do I get a battery for this repair?
Philip Pepin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,242
